Evannnnn's avatar
Evannnnn
Follower
Mar 26, 2022
Cant connect to Fios
I just switched my network to Fios but it doesn't work when I switch from their G3100 router to my own R6700 router. I have tried many things like reset the router, reboot the ONT, and releasing DCHP but it still does not work. I contacted Fios support and they told me that my router is faulty, but I was using that router with another company a few days ago until I switched to Fios now. I would like to know if there is any way to use my own router.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Do you mean that you want to replace the G3100 with the R6700?
    Sadly "does not work" doesn't tell us much. What happens when you try?
