Japio
Apr 20, 2023Aspirant
Can't connect to readyshare WIN10
Hi, I have a R7000 Nighthawk router (latest firmware) and try to connect some USB storage to it. I have tried several. Connecting to the router goes ok, the router finds the drive and it is possi...
michaelkenward
Apr 21, 2023Guru - Experienced User
How is it formatted?
What are the USB drive requirements for ReadySHARE on my NETGEAR router? | Answer | NETGEAR Support
What sort of USB storage? Is it anywhere on this list?
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
That isn't up to date or complete, but it offers some guidance.
But, in windows network it finds the netgear router as a networkthing and also as a computer. But not as storage.
Windows does not like it if you use old and "unsafe" network security features.
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
- JapioApr 21, 2023Aspirant
It is FAT formatted but I tried NTFS as well.
I tried several different storage devices. USB stick, USB SSD, USB HDD.
They are without login protection.
None of them worked.
For SMBv1, something strange happened.
I enabled it but wanted to check if it is still enabled but now it is no longer in the features list. I don't know how to get it back.
I tried a lot of other changes in Windows, for instance in lanmanserver in regedit.
Nothing worked for now.- michaelkenwardApr 21, 2023Guru - Experienced User
I enabled it but wanted to check if it is still enabled but now it is no longer in the features list. I don't know how to get it back.Microsoft loves moving things around.
Where are you looking?
- Start
- Features
- Turn Windows features on or off
