truthlesshero
Jul 19, 2016Guide
Can't connect to router (even after reset)
I'm really frustrated and I hope this community can provide an answer. After all the hype around this router, it's the one that's given me the most problems. About a month and a half ago...com...
- Jul 27, 2016
The router worked fine until about a month and a half ago. Then I stopped being able to connect to the admin page. Multiple hard resets didn't do anything.
I ended up RMA'ing it and the new replacement works fine (at the moment).
Retired_Member
Jul 19, 2016you have to use a wired PC and reboot it and the router while connected via any lan port and re-enter all your settings
- truthlessheroJul 19, 2016Guide
Did that. Both connected to the modem and not. Doesn't work.
- Retired_MemberJul 19, 2016
Just to be clear is it that you cannot connect to internet using the r7000 or you cannot connect to the router's Admin page if the latter un install anti-virus and try again.
i don't have an antivirus. And i can't connect to the admin page right after a hard reset. There is literally nothing to block it..fresh install, fresh reset.
