truthlesshero
Jul 19, 2016Guide
Can't connect to router (even after reset)
I'm really frustrated and I hope this community can provide an answer. After all the hype around this router, it's the one that's given me the most problems. About a month and a half ago...com...
- Jul 27, 2016
The router worked fine until about a month and a half ago. Then I stopped being able to connect to the admin page. Multiple hard resets didn't do anything.
I ended up RMA'ing it and the new replacement works fine (at the moment).
truthlesshero
Jul 19, 2016Guide
to answer the questions,
gateway IP did change after reset. I've tried it (192.168.1.1) and same problem as before reset...web page is not available.
the modem is not in router mode. Everything else wouldn't be working if it was.
I don't have windows. I use linux. netstat shows everything fine. I can ping the router without a problem. I'm having the same problems after the update than i did before. And since I can't reach the admin page, I can't reload the older firmware (which also had the problme which is why i'm here...)
I'm using the latest firmware. I can't do anything about the firmware. I cannot log in to the webpage. It upgrade the firmware during first run but I can't actully get to the admin page. It did not work before the hard reset...it's the reason i did the hard reset. As I've said, i've tried wired, wireless, direct connect, multiple devices.
I've tried different browsers (chrome, firefox), laptop, chromebook, android phone, PC.
IrvSp
Jul 19, 2016Master
Ahh, it is in Access Point mode...
routerlogin.net will only work when it is acting as the DNS server.
You need to log into the main router that the AP is connected to and see what IP Address the AP is at. Note that they must be on the SAME subnet too. If you had changed the IP Address of the main router YYY.YYY.Y.xxx (Y's are the changed value) do to a reset then you can't even get to the AP. 'Y's' must be the same on both router and AP.
Might have to do the RESET on both router and AP and manually reconfigure both?
