truthlesshero
Jul 19, 2016Guide
Can't connect to router (even after reset)
I'm really frustrated and I hope this community can provide an answer. After all the hype around this router, it's the one that's given me the most problems. About a month and a half ago...com...
- Jul 27, 2016
The router worked fine until about a month and a half ago. Then I stopped being able to connect to the admin page. Multiple hard resets didn't do anything.
I ended up RMA'ing it and the new replacement works fine (at the moment).
VE6CGX
Jul 19, 2016Master
What is your modem? What do you mean by saying modem is not in router mode? Separate modem from router(disconnect cable).
Just try the router with only PC connected to it. How did you get into this problem? Router never worked? When you reset the router.
hold the reset button down until lights start flashing then release the botton.
truthlesshero
Jul 27, 2016Guide
