mc510
May 28, 2019Guide
Can't create account to use Circle
Trying to get Circle going on my R7000. I enabled it on my router, then downloaded the Circle app on my Android device ... app says my router is compatible, I use it to log in to my router account, "...
- May 29, 2019
Have you tried this issue in the section given over to Circle?
Circle Smart Parental Controls - NETGEAR Communities
michaelkenward
May 29, 2019Guru - Experienced User
- mc510May 29, 2019Guide
Oh, thanks; that's exactly what I should do! Not sure how I missed that...:robotlol:
- michaelkenwardMay 29, 2019Guru - Experienced User
Unfortunately, this place is a bit of a mess on the organisation front. You are by no means the first to have missed that. You won't be the last.
