Jamieh1979
Jan 06, 2021Aspirant
Cant establish secure connection
Trying to access Google classroom for my daughter and keep getting error messages. The attached is the message on safari but also get similar messages with Edge (your connection isn't private - NWT::E...
- Jan 06, 2021
try using googles dns at 8.8.8.8 or 8.8.4.4or cloudfare at 1.1.1.1
it could be a dns issue with your isp
Jan 06, 2021Guru - Experienced User
What modem do you have?
What firmware is on the router?
Do you have armor activated?
Does any other device have issues or just the one?
doe sit happen over wifi or wired?
