Jamieh1979
Jan 06, 2021Aspirant
Cant establish secure connection
Trying to access Google classroom for my daughter and keep getting error messages. The attached is the message on safari but also get similar messages with Edge (your connection isn't private - NWT::E...
- Jan 06, 2021
try using googles dns at 8.8.8.8 or 8.8.4.4or cloudfare at 1.1.1.1
it could be a dns issue with your isp
Jan 06, 2021Guru - Experienced User
What modem do you have?
What firmware is on the router?
Do you have armor activated?
Does any other device have issues or just the one?
doe sit happen over wifi or wired?
Jamieh1979
Hi thanks for the reply
What modem do you have? R8000 (X6 AC3200)
What firmware is on the router? V1.0.4.66_10.1.75
Do you have armor activated? Yes
Does any other device have issues or just the one? Just the Mac and it appears to be just Google meet but may affect others sites
doe sit happen over wifi or wired? It's connected over WiFi, can't establish a wired connection due to location of devices
- plemansJan 06, 2021Guru - Experienced User
have you check if its armor blocking it?
https://kb.netgear.com/000061032/NETGEAR-Armor-is-blocking-URLs-that-I-want-to-access-what-do-I-do
- Jamieh1979Jan 06, 2021AspirantHi
It was my first thought that it was Armor blocking it but it is not showing up as being blocked by armor in the threat list. And I also disable Armor and still got the same error messages.- plemansJan 06, 2021Guru - Experienced User
