Jamieh1979
Jan 06, 2021Aspirant
Cant establish secure connection
Trying to access Google classroom for my daughter and keep getting error messages. The attached is the message on safari but also get similar messages with Edge (your connection isn't private - NWT::E...
- Jan 06, 2021
try using googles dns at 8.8.8.8 or 8.8.4.4or cloudfare at 1.1.1.1
it could be a dns issue with your isp
Jamieh1979
That DNS suggestion was just the biscuit! Thank you so much, you're a superstar!
Jan 06, 2021Guru - Experienced User
glad it worked!
