dumbttt
Jul 08, 2023Follower
Can't factory reset R6700v3?
I'm following the instructions from here: https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router The lights blink, router turns off and restarts but keeps all the same...
Kitsap
Jul 08, 2023Master
dumbttt wrote:I'm following the instructions from here:
The lights blink, router turns off and restarts but keeps all the same settings. How do I factory reset this router? Any ideas?
I have the latest firmware version: V1.0.4.128_10.0.104
You might want to try a little longer than 7 seconds. It is not a precision part of the operation unless you cut it too short.
Ten to fifteen seconds will not hurt. You will know you have been successful when the default SSID on the label starts broadcasting over Wi-Fi. I have seen some devices that took more than one reset to be successful.
