dumbttt
Jul 08, 2023Follower
Can't factory reset R6700v3?
I'm following the instructions from here: https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router The lights blink, router turns off and restarts but keeps all the same...
Jul 09, 2023Guru - Experienced User
You could also try doing it through the gui.
michaelkenward
Good idea. Often missed.
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
- Select ADVANCED > Administration > Backup Settings.
- Click the Erase button.
Get familiar with that page. It is also useful for saving your settings.
