Retired_Member's avatar
Retired_Member
Apr 08, 2019
Cant get gig internet on r7000
I just got gig internet but I can't get the right speeds I have turned off  QoS , Parental Controls, Traffic Meter and Access Control but some odd reason I only can get 400 Mbps up and 400 Mbps down ...
  • Retired_Member's avatar
    Retired_Member
    Apr 08, 2019
    I did a Revert to factory settings and that fix the problem
