Retired_Member
Apr 08, 2019Cant get gig internet on r7000
I just got gig internet but I can't get the right speeds I have turned off QoS , Parental Controls, Traffic Meter and Access Control but some odd reason I only can get 400 Mbps up and 400 Mbps down ...
- Retired_MemberApr 08, 2019
I did a Revert to factory settings and that fix the problem
Retired_Member
Apr 08, 2019I did a Revert to factory settings and that fix the problem
Apr 08, 2019Guru - Experienced User
Glad to hear it worked!
