JDahmer
Feb 26, 2023Aspirant
Can't get my iphone to connet to my Netgear Nighthawk AC1900
I have a NightHawk Netgear AC1900 router and everything was working fine then the next day my phone or tablet cannot connect to my AC1900. It is statings Incorrect password for Netgear77-5g. I tried...
JDahmer
It is Model number R6900P and when I type in router login.net it takes me to the Netgear homepage. I am using a real computer connected to the netgear and cable modem.
Feb 27, 2023Guru - Experienced User
You're in a double nat as Kitsap says prior based off your modem info.
so the routerlogin address probably won't work. and the netgear router more than likely is on a different IP address from stock because of the double nat.
Try 10.0.0.1 when you're hardwired into the netgear.
Or 192.168.0.1
Those are the 2x other default addresses when the 192.168.1.1 address is already in use (by your arris).
From there you should be able to access the router and make changes to it. (and fix your double nat)
