dbonneville
Mar 26, 2019Follower
Can't get Time Machine to work with Nighthawk
Mac OS Mojave 10.14.3
Nighthawk(R) X4S R7800
Router Firmware Version V1.0.2.62 (just updated)
I bought a new 1TB Seagate SSD external HD. I formatted it according to the instructions low...
papagordie
May 08, 2019Guide
Running High Sierra with this router running Firmware V1.3.1.64_10.1.36.
I have a USB drive attached to the USB 3 port and can mount the volume via smb://readyshare/USB_Storage
Initially via Command-K (Connect to Server) I enter the admin credentials to log in to the R7000P. So far, so good. However, when I open Time Machine's preferences and click "Select Backup Disk..." first I am presented with the option to choose a disk and I click "USB_Storage. I click "Use Disk" and first get a dialog box saying, "You are attempting to connect to the server "R7000P." I click "connect" and get another login window. I choose "Registered User," enter my credentials to login to the server and it gets rejected as if either the Name or Password is wrong. I can't think of any other credentials that would work here other than the sames ones I used to log in in the first place.
I have changed the password a couple of times after reading on the NETGEAR forum about possible issues with characters, particularly the $ sign. I also shortened the password to see if that was an issue. Nothing has made any difference. I get to that same spot in the seteup and my credentials get rejected.
One other oddity to me is that if I click the shared volume in the Finder's sidebar it opens up with R7000P and readyshare which appear as folders. If i double-click "readyshare" it shows I am connected as admin. If I double-click R7000P it shows: "Connected as: Guest." If I click the "Connect as.." button it then shows as "Not Connected." If I back out of that window and then return it shows me as connected again. I cannot disconnect and cannot connect as admin. This strikes me very odd but perhaps it is expected behaviour. The same behaviour occurs when double-clicking readyshare. I click "Disconnect" it changes to "Not Connected" but if I back out and then return by double-clicking readyshare it shows me again connected as admin.
I have searched everywhere I can think of and tried random suggestions, obviously none of which worked.
I sure hope someone is following this thread and has suggestions because I am baffled by this and frustrated I cannot get Time Machine to work as advertised for this router.
mrbillypete
Aug 20, 2019Aspirant
Firmware Version V1.3.1.64_10.1.36
This discribes my situation exactly.
It is frustrating.
