dbonneville
Mar 26, 2019Follower
Can't get Time Machine to work with Nighthawk
Mac OS Mojave 10.14.3
Nighthawk(R) X4S R7800
Router Firmware Version V1.0.2.62 (just updated)
I bought a new 1TB Seagate SSD external HD. I formatted it according to the instructions low...
IrvSp
Aug 20, 2019Master
Folks, NG has a list of tested and verified USB drives for routers. See https://kb.netgear.com/18985/Will-my-USB-drive-work-with-ReadySHARE.
Yes, there are probably many others that work, but are not on the list.
That said, I have never seen any drives larger that 5TB's reported as working. USB drives also have other requirements due to NG's FileSystem used in the router. One is it must be a single partition. Another is the load it places on the port, so generally some portable drives that derive power from the port might need more than available.
I suggest testing with a 2TB or smaller drive to see if that will work.
As for the file system on the drive requirements, check here, https://kb.netgear.com/24059/What-are-the-USB-drive-requirements-for-my-Nighthawk-router.
