dbonneville
Mar 26, 2019Follower
Can't get Time Machine to work with Nighthawk
Mac OS Mojave 10.14.3
Nighthawk(R) X4S R7800
Router Firmware Version V1.0.2.62 (just updated)
I bought a new 1TB Seagate SSD external HD. I formatted it according to the instructions low...
TomWolfe
Aug 20, 2019Tutor
Well, the final answer is that Nighthawk routers no longer support Time Machine. That's a pity, as TimeMachine support was why I purchased this router in the first place.
myersw
Aug 20, 2019Master
TomWolfe wrote:Well, the final answer is that Nighthawk routers no longer support Time Machine. That's a pity, as TimeMachine support was why I purchased this router in the first place.
Welcome to the wonderful world of Netgear. In their infinite wisdom they decided that folks wanted Armor over the services that were listed on the box/documents. In order to do that they had to remove features like yours. Bet you were really wanting/hoping you could get Armor! ;)
Now is not that nice? You bought this router for, in your case Time Machine. Now kiss that good by unless you want to stay on a back level of firmware and never get updates. Aren't you glad you bought Netgear? Firmware support IMHO is crap and has been.
