dbonneville
Mar 26, 2019Follower
Can't get Time Machine to work with Nighthawk
Mac OS Mojave 10.14.3
Nighthawk(R) X4S R7800
Router Firmware Version V1.0.2.62 (just updated)
I bought a new 1TB Seagate SSD external HD. I formatted it according to the instructions low...
papagordie
Mar 19, 2020Guide
At the moment Time Machine is backing up to my 2nd drive . I say "at the moment" because I do not know if it will smoothly rotate to my other, original backup drive. I suspect I will confirm that tomorrow.
In the meantime, some updates to how this worked for me in relation to the guide posted by wkuchrisn
First, this is my experience at Step 3 - Time Machine Setup
I somehow missed your post regarding using the -a flag.
Hopefully this will continue to work. Here is what happened.
I had the sparse image mounted and then ran the initial Terminal command. When I then went to Time Machine preferences it had selected the mounted sparse image as the Time Machine destination. I was now in a bit of a panic. While it would not erase my original Time Machine backup it would be somewhat challenging to re-connect the original Time Machine backup without losing all my backups.
Fortunately, as soon as I clicked the button to choose a backup disk I was immediately prompted by Time Machine to confirm if I wished to use the selected disk, my sparse image, or if I wanted to use both disks, the other being my existing Time Machine backup drive, and rotate between them. One hurdle avoided. I selected both then followed the rest of your guide for Step 4 - "Router Setup" and Step 5. "Mac Setup (aka Return of the Mac)."
Everything clicked along nicely with these following exceptions in Step 5, sections d and e.
Section d:
I noticed when logged in to my router and looking at ReadyShare it showed the T_Drive as having the correct amount of storage space. However, the USB_Storage only shows a small amount of storage. In my case it displays 196.9MB. It would seem that is due to the size I chose for my sparse image, which is the amount of storage space shown for the T_Drive. I did not try and find out if it mattered and selected the T_Drive as you suggested.
Using the reboot option in the router's Advanced settings failed to show the newly connected drive in my setup. I also have a Netgear Ethernet switch so decided to unplug both my router and the switch and reboot them that way. As soon as I was back online the new drive mounted through my router and showed in ReadyShare.
As I said at the start, at the moment Time Machine is smoothly performing its first backup to the sparse image so I am pretty thrilled right now.
Thanks again for the guide and assistance along the way. I will post an update as soon as I know if Time Machine correctly rotates to the other drive.
papagordie
Mar 21, 2020Guide
The two backups have, so far, been humming along nicely, switching back and forth every hour. I ran a check with "The Time Machine Mechanic - T2M2" and it shows zero errors.
This is great news at this stage and again I am most appreciative to wkuchrisn for the help along the way.
