dbonneville
Mar 26, 2019Follower
Can't get Time Machine to work with Nighthawk
Mac OS Mojave 10.14.3
Nighthawk(R) X4S R7800
Router Firmware Version V1.0.2.62 (just updated)
I bought a new 1TB Seagate SSD external HD. I formatted it according to the instructions low...
wkuchrisn
Apr 25, 2020Star
BMac123456 Are you sure it's actually mounting? I'm not familiar with routerlogin.net, but mine always needed the actual share name, like `readyshare` or the like. It could be the same path, I'm not sure.
efish When are you getting this error? Maybe try following this guide: https://discussions.apple.com/thread/6689621 . It's hard to help because I don't know what you've already done and what you've tried.
efish
Apr 25, 2020Aspirant
wkuchrisn Thanks - Sorry for the lack of information.
I've done everything up to 5f with success.
When pressing 'Backup now' (this is the first try after putting USB into router) I get the message you posted earlier. See screenshot.
I'll do some more digging and report back if I get lucky.
Either way, thanks for your guide!
- BMac123456Apr 25, 2020Aspirant
Wow! At least you were able to get Time Machine to even list your hard drive! I can't even make that happen.
