dbonneville
Mar 26, 2019Follower
Can't get Time Machine to work with Nighthawk
Mac OS Mojave 10.14.3
Nighthawk(R) X4S R7800
Router Firmware Version V1.0.2.62 (just updated)
I bought a new 1TB Seagate SSD external HD. I formatted it according to the instructions low...
jGlass314
Jun 26, 2020Aspirant
Hi all. Thank you for all of the information you've posted. My issue with Time Machine is that the router-connected drive does not automount when my mac connects to the router's wifi signal. While I haven't tried most of the steps recommended (as I was somehow already able to manually mount and start a backup to the drive), I'm stuck on step 5.
For starters, while I was able to connect to smb://readyshare through the finder "Go" menu the other day, I get an error now:
There was a problem connecting to the server “readyshare”.
The server may not exist or it is unavailable at this time. Check the server name or IP address, check your network connection, and then try again.
I am able to connect to afp://routerlogin.net (manually), but not with my credentials. I've tried every combination of username and password I can think of. admin/<passoword I set on the router> definitely does not work, even though it does work when logging into the admin panel at http://http://www.routerlogin.net/.
I am able to connect as a Guest and start the backup. The main issue I'm having is the automount. Even before reading this thread, I performed step 5g. However, after a disconnect and reconnect to the network, the window for that step shows two yellow triangles (can't figure out how to insert a screenshot here) next to the drives I want to automount on login. The help menu for that preferences panel states:
If you see a yellow triangle next to an item, the item won’t open automatically because it was moved or deleted.
I have to return to the Finder and again mount the drives through afp://routerlogin.net as a Guest.
Another oddity is that, when I first mount the drive, Finder tabs for both USB_Storage and T_Drive (which is a separate partition on the external HDD) automatically pop up, but they don't show up in the left pane of the finder window. All that does show up is a "Location" object called R7000P, which I assume is my router as that's the router's model number. When I click that object, the finder window shows no files, only a message "Connection Failed" on the top left and a "Connect As..." button on the top right. If I click that button, the two drives immediatly unmount and there is no prompt to log in again. I have to again go to the Finder -> Go -> Connect to Server... menu and again log in and mount the drives through afp://routerlogin.net as a Guest. This is driving me absolutely batty!! (FWIW, after remounting, when the finder tabs open for the partitions, I am able to do a Get Info on each one, and they show "Server: afp://routerlogin.net/USB_Storage" and "Server: afp://routerlogin.net/T_Drive" respectively.)
Any ideas would be very much appreciated. I tried tech support 2 days ago when the router spontaneously rebooted and wiped the logs during a video conference call, and after more than an hour of waiting, the support person concluded the router lost power due to inclimate weather. The skies were blue and clear. The sun was shining. The birds were chirping. And no other electronic device in my apartment--including ones connected to the same power strip--suffered any loss of power. In short, there's no way in helll I'm going through that again.
Firmware Version
V1.3.1.64_10.1.36
macOS Catalina 10.15.5
- mbwaterdogJul 27, 2020Aspirant
I made it all to way to the "TM is backing up, estimated time remaining: " stage! Unfortunately, the NAS unmounts about 3 min into the TM backup. I've tested large files transers outside of TM and those work fine, but for some reason it won't complete a TM backup. Very annoying. I've followed all the steps outlined above (creating sparsebundle .dmg, smb://myIP, etc. etc.). Has anyone encountered this issue and developed a solution? I've searched the forum exhaustively and cannot figure out my TM is unmounting from the network during backup... note that when it unmounts, it is not just the .dmg, but the entire NAS drive, requiring me to re-connect (it won't auto reconnect).
Router: Netgear R7960P (Costco)
NAS drive: Seagate backup+ formatted as Mac OS Extended Journaled
Computer: 2019 16" MBP running OS Catalina
Operator: Frustrated human
