TitaCorrales
May 18, 2017Aspirant
Can't log in my router with laptop
Hi, I am having a problem trying to log in into my router via my laptop with windows 10. I can log in with my iPad or iPhone using the IP address but when I want to log in with my laptop thru my wifi...
- May 19, 2017
I think I found the problem. I unistalled Kaspersky and I was able to log in. I am reinstalling it right now, let see if that fix the problem.
TitaCorrales
May 19, 2017Aspirant
Yes. I receive a message that is the proxy or firewall. But I checked and everythings looks normal. I can connect to the wifi and surf the internet. The problem is when I want ti log in the router sertings. I can log in with my iPhone but not with my laptop.
michaelkenward
May 19, 2017Guru - Experienced User
A message in Windows?
That can be very picky when is comes to network settings.
- TitaCorralesMay 19, 2017Aspirant
So, what do you think it is. It happens with the explorer and with chrome
- michaelkenwardMay 19, 2017Guru - Experienced User
TitaCorrales wrote:It happens with the explorer and with chrome
I am confused. I thought you were asking about logging into your wifi on a Windows 10 laptop.
The browser does not come into this. That's not how you connect to the wifi in Windows 10.
Where is this error message about the proxy or firewall?
Have you ever got this laptop to join a wifi network?
Yes, it's in the network and I can surf and connect with the other computers. The problem is when I try to log in to the router settings. I was able to do it before but now I can't. I do not know if somebody mess with the settings on my laptop.
