TitaCorrales
May 18, 2017Aspirant
Can't log in my router with laptop
Hi, I am having a problem trying to log in into my router via my laptop with windows 10. I can log in with my iPad or iPhone using the IP address but when I want to log in with my laptop thru my wifi...
- May 19, 2017
I think I found the problem. I unistalled Kaspersky and I was able to log in. I am reinstalling it right now, let see if that fix the problem.
michaelkenward
May 19, 2017Guru - Experienced User
TitaCorrales wrote:
Yes. I receive a message that is the proxy or firewall.
A message in Windows?
That can be very picky when is comes to network settings.
TitaCorrales
May 19, 2017Aspirant
So, what do you think it is. It happens with the explorer and with chrome
- michaelkenwardMay 19, 2017Guru - Experienced User
TitaCorrales wrote:It happens with the explorer and with chrome
I am confused. I thought you were asking about logging into your wifi on a Windows 10 laptop.
The browser does not come into this. That's not how you connect to the wifi in Windows 10.
Where is this error message about the proxy or firewall?
Have you ever got this laptop to join a wifi network?
- TitaCorralesMay 19, 2017Aspirant
Yes, it's in the network and I can surf and connect with the other computers. The problem is when I try to log in to the router settings. I was able to do it before but now I can't. I do not know if somebody mess with the settings on my laptop.
TitaCorrales wrote:The problem is when I try to log in to the router settings.
So, you can connect to the wifi and you can connect to the Internet.
You cannot connect to the router's control interface?
That's a common complaint. For example:
If you cannot login to your router | Answer | NETGEAR Support
and this:
Solved: Re: DGN2200v4 Can't login after install - NETGEAR Communities
