TitaCorrales
May 19, 2017Aspirant
Can't log in my router with laptop
Hi, I am having a problem trying to log in into my router via my laptop with windows 10. I can log in with my iPad or iPhone using the IP address but when I want to log in with my laptop thru my wifi...
- May 19, 2017
I think I found the problem. I unistalled Kaspersky and I was able to log in. I am reinstalling it right now, let see if that fix the problem.
TitaCorrales
Yes, it's in the network and I can surf and connect with the other computers. The problem is when I try to log in to the router settings. I was able to do it before but now I can't. I do not know if somebody mess with the settings on my laptop.
michaelkenward
May 19, 2017Guru - Experienced User
TitaCorrales wrote:The problem is when I try to log in to the router settings.
So, you can connect to the wifi and you can connect to the Internet.
You cannot connect to the router's control interface?
That's a common complaint. For example:
If you cannot login to your router | Answer | NETGEAR Support
and this:
Solved: Re: DGN2200v4 Can't login after install - NETGEAR Communities
