Al_L
Oct 11, 2017Follower
Can't log in to www.routerlogin.net
I got an email about doing a firmware update on my Nighthawk R7000-100NAS router. What I have written down as either my username or password must be wrong because www.routerlogin.net won't let me si...
- Jun 27, 2018
Hi Sanhtu,
Please open reference link below of how to access router UI:
How do I log in to my NETGEAR home router?
How to troubleshoot routerlogin.net and routerlogin.com access errors
Blanca
Community Team
ROUTERS
Oct 11, 2017Aspirant
You must find your local router IP Simple 192.168.1.1 192.168.0.1 10.0.0.1 etc...
after you can access to panel.
- antinodeOct 11, 2017Guru
A full ("factory") reset is the usual recommendation for a lost admin
password. After a full reset, you'll need to reconfigure the thing, of
course. The User Manual should explain how to do this. Visit
netgear.com/support, put in your model number, and look for
Documentation.- JmandalaFeb 11, 2018Aspirant
I couldn’t log in to the NETGEAR router to change the security setting. I was using an IPad. I tried my cell phone with a google web browser and typed in the the router’s IP address in the search window. Low and behold the login page came up and I used “admin” for the user I’d and “password” for the password. I was able to change the security setting instantly.
