kasek
Jul 30, 2019Aspirant
Cant log into night hawk r7000
I recently got a raspberry pi to set up pi hole and pivpn. It requires me to log into my router to be able to hook them up. I have the netgear genie app installed on my pc and when I try and log into...
- Aug 02, 2019
kasek wrote:
AP mode?There is support material for the R7000, including a manual, at the end of this link:
>>>> R7000 | Product | Support | NETGEAR <<<<
See the section Use the Router as a Wireless Access Point.
michaelkenward
Jul 31, 2019Guru - Experienced User
kasek wrote:
I dont know if this would affect anything but I am a renter and have a wifi booster plugged into the wall downstairs and then an ethernet cable plugged from that to my router.
Possibly. If there is already a router "upstream" of your device, you are asking for trouble.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
So, what provides your Internet? A modem/router of some sort?
kasek
Aug 01, 2019Aspirant
Thanks for the reply, I believe he has it hooked up like this:
Modem > router > booster (plugged into the wall and hooked up via Ethernet upstairs) > booster (plugged into th e wall downstairs) > my router (via Ethernet) > my pc (Ethernet)
I get the conflict with the double routers. How ever my previous basement suite I was able to log into it, I actually bought it while in that place. It was hooked up : modem> Router> Ethernet cable ran downstairs > my router
Only difference I can see is the booster but I have no way of removing that
- michaelkenwardAug 01, 2019Guru - Experienced User
kasek wrote:
I get the conflict with the double routers. How ever my previous basement suite I was able to log into it, I actually bought it while in that place. It was hooked up : modem> Router> Ethernet cable ran downstairs > my routerThat's odd. Two routers usually cause these problems. Maybe your previous location had something else.
The obvious answer is to switch your R7000 to AP mode.
- kasekAug 01, 2019AspirantAP mode?
- michaelkenwardAug 02, 2019Guru - Experienced User
