kasek
Jul 30, 2019Aspirant
Cant log into night hawk r7000
I recently got a raspberry pi to set up pi hole and pivpn. It requires me to log into my router to be able to hook them up. I have the netgear genie app installed on my pc and when I try and log into...
- Aug 02, 2019
kasek wrote:
AP mode?There is support material for the R7000, including a manual, at the end of this link:
>>>> R7000 | Product | Support | NETGEAR <<<<
See the section Use the Router as a Wireless Access Point.
kasek
Aug 01, 2019Aspirant
Thanks for the reply, I believe he has it hooked up like this:
Modem > router > booster (plugged into the wall and hooked up via Ethernet upstairs) > booster (plugged into th e wall downstairs) > my router (via Ethernet) > my pc (Ethernet)
I get the conflict with the double routers. How ever my previous basement suite I was able to log into it, I actually bought it while in that place. It was hooked up : modem> Router> Ethernet cable ran downstairs > my router
Only difference I can see is the booster but I have no way of removing that
michaelkenward
Aug 01, 2019Guru - Experienced User
That's odd. Two routers usually cause these problems. Maybe your previous location had something else.
The obvious answer is to switch your R7000 to AP mode.
- kasekAug 01, 2019AspirantAP mode?
- michaelkenwardAug 02, 2019Guru - Experienced User
- kasekAug 02, 2019AspirantI have it set up right now as an access point. The internet cable from my booster is in port 1 not the internet port. My pc is running into port 4, and all my wireless stuff (iPhone, xbox, iPad etc) use the wifi from my router. I just don’t understand why I can’t log into it now but at the old place almost same setup I could.
