kasek
Jul 30, 2019Aspirant
Cant log into night hawk r7000
I recently got a raspberry pi to set up pi hole and pivpn. It requires me to log into my router to be able to hook them up. I have the netgear genie app installed on my pc and when I try and log into...
- Aug 02, 2019
kasek wrote:
AP mode?There is support material for the R7000, including a manual, at the end of this link:
>>>> R7000 | Product | Support | NETGEAR <<<<
See the section Use the Router as a Wireless Access Point.
kasek
Aug 01, 2019Aspirant
AP mode?
michaelkenward
Aug 02, 2019Guru - Experienced User
kasek wrote:
AP mode?
- kasekAug 02, 2019AspirantI have it set up right now as an access point. The internet cable from my booster is in port 1 not the internet port. My pc is running into port 4, and all my wireless stuff (iPhone, xbox, iPad etc) use the wifi from my router. I just don’t understand why I can’t log into it now but at the old place almost same setup I could.
- antinodeAug 02, 2019Guru
> [...] a wifi booster [...]
I'll bite. What's "a wifi booster"? Does this one have a maker and
model number?> I have it set up right now as an access point. The internet cable from
> my booster is in port 1 not the internet port. [...]Why? Did you look at the relevant instructions in the R7000 User
Manual?What, exactly, fails, how, exactly? "Can[']t" is not a useful
problem description. It does not say what you did. It does not say
what happened when you did it. As usual, showing actual actions with
their actual results (error messages, LED indicators, ...) can be more
helpful than vague descriptions or interpretations.- kasekAug 02, 2019AspirantI’m at work right now I’ll take a look at home at the instructions you posted. I had hooked up this way by the manual that was in the box when I bought it. So I just hooked it up the same way this time. I’ll get the model and name of the booster when I get home as well. The can’t can’t log in error message is the same as posted in the original post.
- michaelkenwardAug 03, 2019Guru - Experienced User
kasek wrote:
I have it set up right now as an access point. The internet cable from my booster is in port 1 not the internet port.Why? Did you read the manual for how to set up a Wireless Access Point? (See above.)
kasek wrote:
I just don’t understand why I can’t log into it now but at the old place almost same setup I could.Different place, different network, especially as you seem to have decided to use an odd setup. The standard login regime is based on the R7000 being a router and not having anything else on the network that gets in the way and confuses the issue.
If the R7000 is running as a wifi access point, you will not be able to login using the same details.
You also lose other features as an AP:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
To login now, you need to track down the IP address of the AP.
If it is broadcasting a wifi signal, then trying point a browser at the IP address of that source.
Then again, who knows what this magic "booster" might be and what sort of network you now have?
kasek wrote:
....all my wireless stuff (iPhone, xbox, iPad etc) use the wifi from my router.By "router" do you mean the R7000 access point?
- kasekAug 03, 2019Aspirant
michaelkenward wrote:
Ill re-read it i had read the hard copy in the box when setting it up years ago.
i will give this a try and see if that works. the booster im using is a tp-link 300mbps wi-fi range extender AV600 powerline edition TL-WPA4220
yes, can i set this up as not an AP then? Sorry i know nothing about all this stuff. Or am i stuck as an AP being that im running out of their router upstairs?
