Firecapt
Dec 06, 2015Aspirant
Can't log into router after recent firmware upgrade
Just upgraded the firmware on my R7000 from 1.0.4.30_1.1.67 to 1.0.4.48_1.1.79. After the upgrade I have been unable to access the router either using a browser or through Netgear Genie. The router...
- Dec 07, 2015
I just got my router setup again and I decided to use the DHCP reservation again as well for my machines, i do a lot of network file exchanges for files and its just been easier to assign everything through the router, just takes a while for 50ish devices thats including friends and family.
Anyway, thank you everyone, have a Merry Christmas and a Happy New Year.
rpoffen
Dec 07, 2015Virtuoso
I use DHCP reservation for my camera system and it works fine. I have IP addresses from x.x.x.1 to x.x.x.150 assigned for DHCP, and I used a reservation entry to assign x.x.x.151 for my camera. Simple to maintain and it works.
Onyxius
Dec 07, 2015Aspirant
- rpoffenDec 07, 2015Virtuoso
If you really need to have the same IP for a lot of machines, then it is a bit of work, but with DHCP reservations, you only need to keep the router updated. If you truly use static IP, then you have to manage both the router and the client. If you keep a range for DHCP for machines (like mobile devices) that don't care which IP they get, then you don't need to do anything.
