jpeters4877
Sep 14, 2021Follower
Can't log into WiFi from Android phone.
I'm trying to set up my sister-in law so she she can log into her wifi using a new android phone. I know the password is correct (I've loged into and out off the Router successfully several time). Bu...
Sep 14, 2021Guru - Experienced User
What model NG product do you have to confirm?
You marked your post as having a C7000? IF this is the product, please post about this over in the Cable modem forum:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
