JSlocum
Oct 02, 2020Aspirant
Can't Login except through Access Anywhere
I can't seem to find an answer so hopefully someone can point me to one or help. I had to factory reset my router because I wanted to change to a different channel and forgot the login info. Eve...
- Oct 08, 2020
Yes I did, thank you. Actually, I found that in another thread finally. That's what corrected it. Everything is working fine and I was able to add the mesh extender with no issues. I guess you can't have both local and remote access. But, I also read that it may be able to be used for exploits so I'm probably better off without it.
JSlocum
I forgot to add that for www.routerlogin.net/com I did clear cache, tried a different browser, etc. And, on the app side I cleared data and uninstalled and reinstalled the app.
DarrenM
Oct 07, 2020Sr. NETGEAR Moderator
Have you tried to disable the Access Anywhere and then try the IP address?
DarrenM
- JSlocumOct 08, 2020Aspirant
