JSlocum
Oct 02, 2020Aspirant
Can't Login except through Access Anywhere
I can't seem to find an answer so hopefully someone can point me to one or help. I had to factory reset my router because I wanted to change to a different channel and forgot the login info. Eve...
- Oct 08, 2020
Yes I did, thank you. Actually, I found that in another thread finally. That's what corrected it. Everything is working fine and I was able to add the mesh extender with no issues. I guess you can't have both local and remote access. But, I also read that it may be able to be used for exploits so I'm probably better off without it.
DarrenM
Oct 07, 2020Sr. NETGEAR Moderator
Have you tried to disable the Access Anywhere and then try the IP address?
DarrenM
JSlocum
Oct 08, 2020Aspirant
