Wilkins2john's avatar
Wilkins2john
Follower
Jun 09, 2021
Can't login to router login.net
So I login into the router login, And get all the way to the part where it wants me to put my Netgear account in put when I click email it immediately turns red and says email required but it won't let me type anything into the field same thing goes for the password. I'm trying to do port forwarding and I can't figure out how to do it on the nighthawk app
  • > [...] I'm trying to do port forwarding and I can't figure out how to
       Forget the app, and use a web browser?
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.  Look for
    "Set Up Port Forwarding to a Local Server"?
  • michaelkenward's avatar
    michaelkenward
    You don't need a "Netgear account" to access the router's controls.
    Even when you want to use something like "Anywhere Access" on the Nighthawk App, you don't need an email address.
    So what are you trying to login to and what are you trying to login in with? There are separate Android and iOS Nighthawk apps.
