tfox20445
Dec 25, 2021Tutor
can't login to router settings on Netgear Genie
recently upgraded my firmware to v1.0.4.122; now can't get into router settings on Genie: it says: Login failed. The router response timed out. How to fix?
Dec 26, 2021Guru - Experienced User
Try using the NightHawk App on a mobile device or set up the router using PC and web browser.
I beleive the Genie app is no longer supported...
