Lavidar
Sep 18, 2021Aspirant
Can't login to the WAC104 setup UI 192.168.0.100
Hey, I just got the WAC104 and I can't set it up. When pluggin in, it generates 2 wifi networks (NEATGEAR_11N, NETGEAR_11AC) but both require a password (yes, even after I reset it). No passwor...
Lavidar
Sep 19, 2021Aspirant
Hey michaelkenward, thank you for your answer!
I have found the passphrase and loged in - but it still won't load the interdace on the default adress (192.168.0.100).
The wireless icon has an "!" on it - saying it's an unidentified netwrok... but my IP is dynamic
Any other suggestion would be welcomed...
Thanks!
Leo
michaelkenward
Sep 19, 2021Guru - Experienced User
Which wireless icon, and where do you see it?
What does "my IP is dynamic" mean to you? That is usually something to do with your Internet service provider. It describes your IP address on the Internet, not an address on your local network. So a dynamic IP address has nothing to do with 192.168.0.100.
The WAC104 is an access point. What do you have it connected to?
Are you following the instructions in the Initial Setup guide? What router is your WAC104 connected to?
- LavidarSep 19, 2021Aspirant
Hey,
See the photo below regardig the "!" icon.
Maybe the "IP is dynamic" comment is unrelated, it's just something the local support person sayd over the phone, but could not help beyond that point.
Currently it's connect only with the power cord. nothing else.
I tried connecting it to my laptop via an ethernet cable but it still will not connect to the UI.
Thanks.
Leo- michaelkenwardSep 19, 2021Guru - Experienced User
Lavidar wrote:
Hey,
It may be some time before the images land. To ensure that you aren't posting anything naughty, a Netgear moderator has to approve the pictures.
You can attach images to messages without any delay.
- michaelkenwardSep 20, 2021Guru - Experienced User
From what I can make out, that is the Windows networking icon.
Have you tried this:
Fix network connection issues in Windows 10
