Jedi215
Jul 21, 2018Aspirant
Can't make R7900 into AP!
Got a XR500 to make my R7900 into an AP. After setting up the XR500, and following directly directions for setting up the R7900 as an AP, I can't log in to the 7900. Even after doing a reset to see if...
- Jul 23, 2018
Jedi215 wrote:
I can't access the R7900 to make the selection to AP.Reset the R7900. Connect the R7900, and only the R7900, to a PC. Then you should be able to access the R7900 with the browser interface and put it into AP mode.
Then move stuff to where you want it. The R7900 will remember that it is supposed to be in AP mode.
When evereything is set up, you should be able to access the R7900 by finding its IP address on the network and using that to browse its controls.
Jedi215
Thank you. I will give this a try later. I'm still extremely aggravated from hrs of torture. May even wait till tomorrow, Lol.
michaelkenward
Jul 22, 2018Guru - Experienced User
And remember this....
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
- antinodeJul 22, 2018Guru
> Got a XR500 to make my R7900 into an AP. [...]
Eh? Does that mean that you got an XR500 to use as a router, and you
have an old R7900 which you want to configure as a wireless access
point? (Because getting an XR500, by itself, would not "make [your]
R7900 into an AP".)
> [...] following directly directions for setting up the R7900 as an AP,
Which "directions [...]"? Which choices did you make?
> [...] I can't log in to the 7900.
When you do what, exactly? "can't" is not a useful useful problem
description. It does not say what you did. It does not say what
happened when you did it. As usual, showing actual actions with their
actual results (error messages, LED indicators, ...) can be more helpful
than vague descriptions or interpretations.
> [...] Even after doing a reset to see if it helps, nothing. [...]
"doing a reset" on what? The XR500? The R7900? (Re: "nothing", see
"can't", above.)
> [...] What am I missing. [...]
What, exactly, are you doing?
> [...] log into the AP again via http://www.routerlogin.net,
> http://www.routerlogin.com,
I don't see how that could work.
> [...] or by typing the IP address of the AP into the browser.
_That_ could work. (_If_ you know that IP address.)
> This is misleading - the routerlogin.net or routerlogin.com can only
> work if you are connected (ie. wireless) to the Access Point. [...]
Not even then, I'd say. I'd expect those "routerlogin.{com|net}"
names to work only to access the router (acting as a DNS server), never
to access a WAP.
> [...] PC sees it in IE browser as me trying to login to the XR500.
That's what I'd expect from any "routerlogin.{com|net}" names. To
access the WAP, I'd expect to need to use its (new) LAN IP address.
Given that, I'd avoid that KB article, and stick to the instructions
in the router User Manual.
When an R7900 is put into WAP mode (ADVANCED > Advanced Setup >
Wireless AP), you decide whether to let the R7900-as-WAP get a LAN IP
address from your (router's) DHCP server ("Get dynamically from existing
router"), or to give it its LAN IP address yourself ("Enable fixed IP
settings on this device (not recommended)"). If you specify the
default, "Get dynamically [...]", then you'd need to extract its LAN IP
address from an "Attached Devices" (or "DHCP Clients", or similar)
report on the "existing router".
For future convenience, you might want to assign a reserved address
for the WAP in the (router's) DHCP server.
Alternatively, you could specify a (static) address "Enable fixed IP
settings [...]"). in which case, you'd know that address. If you do
that, then you'll want to shrink the DHCP pool (on the XR500) from its
usual default (".2" - ".254") to something smaller (like, say, ".2" -
".199"), and then use an address from the non-pool range (".200" -
".254") for the R7900-as-WAP.
> [...] I'm still extremely aggravated from hrs of torture. [...]
Faulty instructions can do that.- schumakuJul 22, 2018Guru - Experienced User
...as well as a factory reset of the router, which does reset the LAN interface to 192.168.1.1/24 ... while having this connected to the XR500 LAN which does (by default, most keep this default anyway) make use of the very same IP address.
Not really. If the freshly reset R7900 is left in router mode, and
its WAN interface were connected to a router which is using the
192.168.1.0/24 subnet, then I'd expect the R7900 to choose a different
LAN subnet. ("10.0.0.0/24" would be my guess.)
In many cases, it can be helpful actually to try these things before
asserting what will happen when someone else tries them.
None of which seems to be relevant to the reported problem.
- Jedi215Jul 22, 2018Aspirant
Wow. I dont know if I uderstand it all, LOL, Sorrry
The XR500 is the main one and Im trying to use the R700 as an AP. I reset the R7900 and I cant get back into it. Im using the directions in https://kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-setup
but this has not worked. I did it first without resetting the R7900 then I reset the R7900 and nothinng.
