MechWarriorZero
Mar 22, 2025Aspirant
Can't Map Network Drives in Windows XP
I Can't Map Network Drives in Windows XP anymore
Mar 23, 2025Guru - Experienced User
what device do you have?
In terms of mapping, you'd have to check on the xp forums. I can't remember the last time I even had an xp computer.
- MechWarriorZeroMar 30, 2025Aspirant
Netgear R7000, I had them map but had to change the folder name and know I can't remap them in windows xp
- plemansMar 31, 2025Guru - Experienced User
If you know you can't remap them, whats the question?
- MechWarriorZeroMar 31, 2025Aspirant
when I tried to map it, its asking for a user and password and I get an error
