SuperBanana63's avatar
Jul 18, 2017
Can't Port Forward Button - Nighthawk x6 R8000
I can't port forward anymore, because when the Port Forward button has turned grey, and now I can't click on it. It has worked in the past.
  • TheEther's avatar
    Jul 18, 2017
    Are you running your router in AP mode?  If yes, then port forwarding doesn't apply.  You would need to set up port forwarding on your main router.
