krubag
Jun 26, 2018Aspirant
can't print wirelessly from Mac but can print from Windows (Nighthawk R7800)
Hello. I've recently upgraded to the Nighthawk router. So much faster than my old Comcast setup. The only issue is I cannot print from a Mac. I have no problem printing from any laptop running Wi...
- Jun 27, 2018
krubag wrote:
The only issue is I cannot print from a Mac. I have no problem printing from any laptop running Windows.
Sort of suggests that you check the printer and its setup.
HP has printer utilities for Windows and Macs. It is probably on your Mac already. Look for it or ask the HP community what to do.
You will also find more if you search this forum for "HP Printer".
antinode
Jun 26, 2018Guru
> [...] (Nighthawk R7800)
Fed by what, some kind of modem(+router)? ISP?
> [...] I can see the printer if logged into routerlogin.net, [...]
"see" how, exactly? Attached Devices report, or what? Can you see
the Mac there, too?
> [...] whenever my MacBookPro (sierra - 10.12.6) tries to connect to
> the printer (HP Officejet Pro 8600), I get a message "An error occurred
> while trying to add the printer".
What, exactly, are you doing? Are you trying to "add the printer",
or "connect to" an existing "the printer"? If the printer is already
installed on the Mac (left over from when the old router was used), then
I'd try removing it, and adding it again (using the new router).
