krubag
Jun 26, 2018Aspirant
can't print wirelessly from Mac but can print from Windows (Nighthawk R7800)
Hello. I've recently upgraded to the Nighthawk router. So much faster than my old Comcast setup. The only issue is I cannot print from a Mac. I have no problem printing from any laptop running Wi...
- Jun 27, 2018
krubag wrote:
The only issue is I cannot print from a Mac. I have no problem printing from any laptop running Windows.
Sort of suggests that you check the printer and its setup.
HP has printer utilities for Windows and Macs. It is probably on your Mac already. Look for it or ask the HP community what to do.
You will also find more if you search this forum for "HP Printer".
michaelkenward
Jun 27, 2018Guru - Experienced User
krubag
Jun 28, 2018Aspirant
I had to get the latest HP drivers from the App Store. Restart printer a couple times, then it finally started printing. Thanks for the help!
