Aandrey
Dec 23, 2024Tutor
Can't Reach This Page, then fixes itself after a second
 Nighthawk X8 model R8500     Firmware Version  V1.0.2.160     Hi everyone, recently struggling with an issue where it seems the DNS does not resolve successfully when I try to go to a website. Then a...
Aandrey
Jan 20, 2024Tutor
So RouterLogin.net did not work, it wouldn't display the webpage. But 192.168.1.1 worked
If anyone was having my problem, once you log in to 192.168.1.1 (default creds are admin/password) you need to go to the advanced tab, then Administration, and then Router Upgrade. It will then give you an option to upload the firmware update file from your PC.
However, this didn't do anything for my real problem, as the router is still "connected without Internet" even after successful upgrade to the latest firmware.
Aandrey
Jan 20, 2024Tutor
Further update: I checked the router status in the Advanced--> administration menu. The ip showed 0.0.0.0 which meant the router couldn't get an IP. so I hard rebooted the modem and router together, and after reboot an IP was assigned and everything works now!
- michaelkenwardJan 21, 2024Guru - Experienced User
 Aandrey wrote:
 so I hard rebooted the modem and router together, and after reboot an IP was assigned and everything works now!When you do that, remember that the timing is important.
 Be sure to restart your network in this sequence:- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
