Aandrey
Dec 23, 2024Tutor
Can't Reach This Page, then fixes itself after a second
 Nighthawk X8 model R8500     Firmware Version  V1.0.2.160     Hi everyone, recently struggling with an issue where it seems the DNS does not resolve successfully when I try to go to a website. Then a...
Aandrey
Jan 20, 2024Tutor
Further update: I checked the router status in the Advanced--> administration menu. The ip showed 0.0.0.0 which meant the router couldn't get an IP. so I hard rebooted the modem and router together, and after reboot an IP was assigned and everything works now!
michaelkenward
Jan 21, 2024Guru - Experienced User
When you do that, remember that the timing is important.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
