Snailstick
Feb 18, 2016Aspirant
Cant register my router to the readyCLOUD account
I am trying to get readyCLOUD up and running. I have created an account on readyCLOUD but when I try to register my router in the router interface with the login and password from readyCLOUD it doesn...
- Feb 19, 2016
Snailstick Can you try to login now on your ReadyCloud account? This should be fixed now.
Let me know if you're still having problems.
Snailstick
Feb 19, 2016Aspirant
Hi oh it's a r7000 ac1900 nighthawk router I think it's called. The version of the firmware is V1.0.5.48_1.1.79.
Is that what you asked for?
ElaineM
Feb 19, 2016NETGEAR Employee Retired
Snailstick Our engineers are aware of this. Will provide an update soon.
- warblerFeb 19, 2016Guide
Have the same exact problem. There is NO ReadyCLOUD radio button with the newest firmware 1.0.2.2. Would appreciate any help. Nighthawk X4 R7500 V2.
- ElaineMFeb 19, 2016NETGEAR Employee Retired
R7500 does not support ReadyCloud.
See the compatibility list here.
Hi Elaine, thank you for the reply. My USB storage access is very limited, i.e. only some files were shown. I thought ReadyCLOUD would register my router and allow access to my USB drive. Is there any way to access my usb drive like Windows File Explorer?
