Snailstick
Feb 18, 2016Aspirant
Cant register my router to the readyCLOUD account
I am trying to get readyCLOUD up and running. I have created an account on readyCLOUD but when I try to register my router in the router interface with the login and password from readyCLOUD it doesn...
- Feb 19, 2016
Snailstick Can you try to login now on your ReadyCloud account? This should be fixed now.
Let me know if you're still having problems.
wyliesdiesels
Mar 21, 2016Guide
Im using an R7000.
I finally got it to work the same day.
After about 2hrs of trying different combinations i got it to work. Not sure what the deal is. I think i also got it to work with firefox after trying with chrome and IE.
ElaineM
Mar 22, 2016NETGEAR Employee Retired
Thanks for the update!
Glad that it's now working.
- rodelcoApr 07, 2016Star
I just purchased and installed an R6400 AC1750 Router and have a WD Passport Ultra 1TB external hard drive plugged in to the USB 3.0 port on the front. I can access this drive from my Windows 10 PC just fine. I am trying to get ReadyCloud set up but am having similar problems to those posted here. I have a ReadyCloud account, and can log in using the web just fine. When I try to register my USB device and router from the router's interface, it says "Registration failed. Please check your user name and password and try again."
