MAFPR
Jun 13, 2016Aspirant
Can't reset router, connect devices, internet working wifi but not ethernet, amber light on internet
Wifi Connectivity was down. When I check it up internet led blinking amber. Disconnect Router and Modem, after connecting it back again wifi radio was off. By that time I was able to log in to the ro...
- Jun 16, 2016
OK everyone sorry for all the confusion with all the Ip addesses and weird gateway codes. The router was in in Access Point mode. Most of the features are disable with this mode and even the router reset button did not want to work. A friend of mine check it out and had to reset it using another router (once he figure it out that the router was behaving as an access point it was a 10 minute fix). After resetting it, even the reset button was working.
What I learned. If you do not have an extra back-up router, do not mess with the router.
Thanks everyone for trying. have a nice day
MAFPR
Have no idea why it says this in the network map info of the router
Router Model N/A
IP Address: 50.130.90.1
Status: Online
MAC Address: C8:4C:75:77:7B:E2
Firmware Version: N/A
VE6CGX
Jun 13, 2016Master
Is the MAC address that of your router? using that ip address, try to ping the router.
