Chryss's avatar
Chryss
Can't reset router password
After doing the most recent firmware update, which added the security questions, my husband stupidly reloaded the old backup settings. Now neither the old or new password is working. I attempted to reset the password using the serial number, but it's telling me the security question answers are incorrect (they aren't.) How can I fix this?
  • > [...] my husband stupidly reloaded the old backup settings. [...]
       It's stupid only because Netgear firmware made it stupid.
    > [...] How can I fix this?
       Settings reset, and manual reconfiguration.  Visit
    http://netgear.com/support , put in your model number, and look for
    Documentation.  Get the User Manual.  Look for "Factory Settings" (or
    "reset").
    "reset").
    • Chryss's avatar
      Chryss
      So, I have to reset to factory default? No other way?
      • antinode's avatar
        antinode
        Guru
           If you can find another way, then you have my permission to have at
        it.  If your expected passwords all fail, and the password recovery
        scheme fails, then I'd guess that you're practically doomed.
           If it were a life-and-death matter, and practicality was not
        required, then you might be able to load some older firmware using the
        TFTP recovery scheme, and plop your old saved settings into that, and
        try again as if nothing had happened.
              https://community.netgear.com/t5/x/x/m-p/1622096
           I probably wouldn't try it, but you could.
