RocketDesigner
Aug 15, 2020Aspirant
Can't restore router firmware after update failure
I tried updating my R6700v3 via the Nighthawk app, and the app displayed an update failed message. I walked over to the router and all the LED lights were on. I have a computer that has a wired conne...
- Aug 16, 2020
Not sure I can offer much help other than..remove all cables from it, and power it up, after 5 minutes what do you see in terms of lights? Still just the Power LED flashing?
If so, sounds like the flash memory could be the culprit...not much that could be done if it's failing other than RMA ...
michaelkenward
Aug 16, 2020Guru - Experienced User
There is more severe, recovery reset, that you could try:
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
If it works, you may be able to use the usual method to flash the firmware again.
Download the latest firmware for your device – or an older version if that is what you want – and read the Release Notes for how to install it.
If that fails, you are into TFTP country.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
This also explains how to tell Windows to use TFTP on your PC.
This isn't the easiest operation, so if you are forced to use it, you could try a web search to find videos that guide you through the process.
The good news is that TFTP has rescued many a dead device.
rinthos
Aug 16, 2020Luminary
michaelkenward wrote:There is more severe, recovery reset, that you could try:
The original poster already noted the recovery reset in their original post, and then tried TFTP and referenced different TFTP KBs they tried...Sounds like they have warranty coverage still, so I'm not aware of anything end-users can do beyond TFTP to force-load firmware...any last resort stuff you can share might be helpful, otherwise I'd still go the RMA route if it's available...
- michaelkenwardAug 16, 2020Guru - Experienced User
rinthos wrote:
The original poster already noted the recovery reset in their original post, and then tried TFTP and referenced different TFTP KBs they tried...It got lost in the saga.
That long message did not convince me that they had done it right. Too much extraneous background detail.
The point about TFTP is that it is a complicated process that needs the right configuration and timing.
If a warranty return works, fine, if not try again without being tricksy. Simply make several attempts to use TFTP as intended. Pay careful attention to all of the messages returned.
- RocketDesignerAug 16, 2020Aspirant
michaelkenward Thank you for the advice. I did try the 30-30-30 hard reset, both alone, followed by tftp, and four minutes after a tftp upload. I have tried various combinations using tftp including:
- Power up actions: the 30-30-30 hard reset, various amounts of time holding reset on power up (7, 10, 30, 60, and 120 seconds), and no reset on power up.
- tftp applications: tried using both Tftpd64 and Windows tftp client
- Timing of the tftp put command: immediately on power up*, when only the Power LED and Ethernet port lights are amber (unit does this for about six seconds before the Power LED starts blinking)*, when Power LED first starts blinking, and after the Power LED blinks 10 times.
(*Only the Windows tftp client works when executed before the power LED starts blinking; Tftpd64 stays stuck on block zero if I execute it before the LED starts blinking. Based on when Windows tftp completes the transfer, it appears that the Windows tftp client simply keeps trying the connection, but the connection doesn't successfully start until the LED starts blinking.)
My unit is still under warranty, and I was able to initiate an RMA. Will be packing up the unit today and mailing it tomorrow.
