tahoe610
Sep 19, 2021Tutor
Cant Run update
Good Morning, I am unable to update the firmware any which way? I have shut off auto updates and still unable to run update. Any help? Thank you!
Sep 19, 2021Guru - Experienced User
What firmware version are you on?
Where is it failing in the process?
Details help us to help you.
so go into full details of whatt you're using, how you're trying, and what error or where its failing.
Have you tried hardwiring into the router and manually updating?
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
- tahoe610Sep 19, 2021Tutor
thank you for anserwing so quikclly. I currenyl have version Firmware Version
V1.4.1.50_1.3.10It is requesting me to update to 1.4.1.68_1.3.28
My computer is hard wired to my router.
I run the update as prompted but the router software still asks me to run update, its as if its not running the update, time and time again.
