bryanboling
Jan 27, 2017Aspirant
Can't save file in Word to Readyshare USB drive
I've got a 500GB external HD connected to my R700 router's USB port. I can open documents in Word (Mac OS X Yosemite) and edit them, but when I try to save them, I get an error message that says "The...
- Jan 30, 2017
Problem solved. I just upgraded to Office 2016. No more issues.
Thanks!
bryanboling
Jan 28, 2017Aspirant
Update: this only appears to be a problem in Word. I just was able to access and save an Excel file. I am also able to download files through Google Chrome and save them to the remote drive.
Help! This is REALLY frustrating....
- StephenBJan 29, 2017Guru - Experienced User
Try adding the ReadyShare drive to Office's trusted location list.
- bryanbolingJan 30, 2017Aspirant
Hmm..this doesn't seem to apply to Word 2011 for Mac. I've looked around but can't figure out a way to do this. From googling around looking for this, it seems that this is a common problem with saving documents from Word 2011 to network servers. I don't know, but could the same problem be happening here? Is this considered a network server?
- StephenBJan 30, 2017Guru - Experienced User
Yes.
