Jradders's avatar
Jradders
Can't see my Router in Windows Explorer
My Nighthawk was sharing files perfectly, but now I can't see the Router in Windows Explorer (Windows 10). Has anyone else had this problem?                 The "Network"...
  • IrvSp's avatar
    IrvSp
    Jun 04, 2018
    Problem could be the CREDENTIAL MANAGER (on Control Panel). Since it is on the Router it probably needs a credential access the ROUTER (UID and PW). When you look at the Credential Manager for the Web tab you will see one for the router (or should). That is why on the PC you don't get prompted for UID and P/W.
    I can't see the 'picture', moderator has to approve it before anyone but you can see it. Better to ADD it with the BROWSE under a reply, that posts immediately.
    What do you mean by "it used to work"?
