Jradders
Jun 03, 2018Aspirant
Can't see my Router in Windows Explorer
My Nighthawk was sharing files perfectly, but now I can't see the Router in Windows Explorer (Windows 10).
Has anyone else had this problem?
The "Network"...
- Jun 04, 2018
Problem could be the CREDENTIAL MANAGER (on Control Panel). Since it is on the Router it probably needs a credential access the ROUTER (UID and PW). When you look at the Credential Manager for the Web tab you will see one for the router (or should). That is why on the PC you don't get prompted for UID and P/W.
I can't see the 'picture', moderator has to approve it before anyone but you can see it. Better to ADD it with the BROWSE under a reply, that posts immediately.
What do you mean by "it used to work"?
Jradders
Jun 04, 2018Aspirant
Hi IrvSp,
I've added in SMB1 and I can now see the Router in Windoes Explorer. Thanks.
Am now stuck between SONOS controller and accessing the Readyshare (USB with music on it).
SONOS will add HDD directories, USB in PC but not ReadyShare (it used to work).
Error is this:
Problem is I can 't find any rights settings in Genie or 192.168.1.1 portal
I don't have any passwords on Readyshare and am just running Basic.
All suggestions welcome....
IrvSp
Jun 04, 2018Master
- JraddersJun 04, 2018Aspirant
RESOLVED.
School boy error.
Nighthawk was working fine.
Discovered the SONOS deektop client wanted the SONOS user id / password to add a service, but the GUI box said password/username for storage device.
Escentially I was using the wrong credentials.
But all working now thank you. Solution was SMB as you first highlighted. Thanks you.
